TwinTurbo.NET: Nissan 300ZX forum - Vacuum leak....
Subject Vacuum leak....
Posted by zx299 on May 08, 2011 at 2:11 AM
  This message has been viewed 237 times.
In Reply To afr too low at low rpm posted by hijack on May 07, 2011 at 09:59 AM
Message When you first start your car it should run rich till it warms up. As the engine warms (and revs fall) the AFR should head toward Stoich.
Check your air regulator, AAC valves, and check for vacuum leaks.
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
